Author Topic: Wheel PCD  (Read 2289 times)
Wheel PCD
« on: October 30, 2017, 18:06:51 »
Does anyone know what the wheel PCD is on a 2 litre saloon?
BE774
Wheel PCD
« Reply #1 on: October 30, 2017, 18:34:49 »
Hi Gary, can you not measure it? It is made up of two figures, the number of studs/bolts and the diameter in mm of the circle drawn through them. Say, 5 x 100. You could use tins from the kitchen cupboards to work this out. Sorry if you know this already.
Barbara
Wheel PCD
« Reply #2 on: November 02, 2017, 09:15:42 »
Cheers tried tins but not any the right size, however I have found a formula and a simple format to measure them. Will go down garage later and check then I can get on with disc brake conversion to front axle.
BE774
Wheel PCD
« Reply #3 on: November 02, 2017, 15:34:53 »
Or a pair of dividers and a bit of cardboard to double-check?
Barbara
