Author Topic: Ace - rubber around front inner guards  (Read 5171 times)
bill griffiths
« on: January 31, 2017, 21:49:09 »
I have seen, but not inherited, a rubber section around the curved apperture of the inner guards where the transverse spring passes on its way to the wheels.
   Perhaps I saw it in a picture, but I have trolled through my entire AC library without success.
   I do not even have the holes where the pop rivets may have gone because new inner guards were fabricated thirty years ago!
   Do I imagine the rubber to be in two sections; is it fastened to the outside of the inner guards and what is its dimensions?
   Any help would be much appreciated.
   Bill Griffiths.
« Reply #1 on: February 02, 2017, 10:13:55 »
   Bill
   Scanned through my pictorial library and found a few pictures
   showing the rubber sheet riveted to the outside of the inner wing
   to keep the engine bay a little cleaner.
   I will fire a few pictures to you later today.  None of the pictures give close up view but should help as a guide .
   The pictures  will be of the following Ace Bristol's :
   BEX487,  BEX489, AEX/BEX ????,  BEX1003  and  BEX1186.
   Maybe the owner of one of these can help with better more accurate data. [?]
bill griffiths
« Reply #2 on: February 02, 2017, 11:02:16 »
Thanks, Keith.
   Marvellous of you!
   Many thanks and kind regards,
   Bill
« Reply #3 on: February 02, 2017, 11:26:52 »
Have you considered the use of single edge brush strips which can be purchased in different brush lengths which are held in an extruded aluminium strip so can be cut to length & riveted to each side of the panel, this allows the suspension & track rods to move with the brushes closing each side of the arms, whereas rubber strips will always have gaps!
« Reply #4 on: February 02, 2017, 16:35:39 »
Maybe some pictures of the inner guards of an Aceca helps.
   Yes, I guess the good times are over for them.
« Reply #5 on: February 02, 2017, 18:36:35 »
I like the brush idea, not terribly 'period' looking, but sounds very practical.
   Some photos from Keith:
   This is BEX 1186:
   BEX 1003:
   BEX ????:
   BEX 489:
« Reply #6 on: February 03, 2017, 09:50:12 »
Bill.
   Check out:   top picture Page 29 of Rinsey Mills
   "Original Ace & Aceca"..[;)]
   Picture and caption makes reference to the rubber sheet attached by pop riveted aluminium strips to each of the inner wings through which the transverse leaf spring passes.
    Clean picture confirming  rivet locations.
« Reply #7 on: February 03, 2017, 10:32:59 »
A couple of great images of AEX1194, courtesy of Jonathan Parker:
TTM
« Reply #8 on: February 03, 2017, 12:50:43 »
Interesting pictures, thanks.
   Should the brake hoses be attached to the springs? Will have to check on mine where (if??) they are attached...
bex1151
« Reply #9 on: February 03, 2017, 18:17:23 »
Bill
   I am restoring BEX1002.  I have lots of pictures of the inner panels and the rubber skirts that came with the car as well as the repaired/resurrected assembly.  My skirts were not riveted to the inner panel, but were, and now are, attached with screws. If you send me an email address (tusherarch@att.net), I'll send you some photos.
   Aloha   Terry
« Reply #10 on: February 04, 2017, 09:36:17 »
   Terry  &  Bill
   Would like to see a few photos so I can make up a set for BEX333.
   Can you either email me details some time or get Nik to post a few pictures with dimensions.
   The wonders of the Internet [;)]  Lets hope more members start using  The Club Forum, the information is out there, just have to ask.
   Last but not least a quick Thank You to Nik for posting pictures on behalf of many members..[:)]...appreciated.
bex1151
« Reply #11 on: February 04, 2017, 19:48:54 »
   I'll email you photos. The inner liners are out of the car but all assembled so I'll include a sketch with dimension.
   aloha   Terry
taffe9
« Reply #12 on: February 04, 2017, 20:17:58 »
Seems to be a lot of agonising regarding a non factory feature on the Aceca but was added by individual owners over the years, see Autosport 12/1/62. Do your own thing, old tyre inner tubes seem popular!
