Author Topic: Mark IV diagnostics?  (Read 2627 times)
gblue
« on: May 13, 2007, 05:58:16 »
Aloha again...is there a obd port to check if there is a problem with one of the cars systems? Is there an on board computer? My owners manual doesn't mention one.....Mahalo from Maui.....Gregg
ak1234
« Reply #1 on: May 13, 2007, 12:46:21 »
I;m under the impression that behind the passanger side kick board ..pull back the carpet and theres a trap door .. the silver box is the computer for my car.
   Ron
« Reply #2 on: May 13, 2007, 13:54:44 »
Rick - MKIV - You're pretty good on this type question. Jim
« Reply #3 on: May 13, 2007, 18:50:21 »
EFI cars have a full EEC II unit, 85's have one that runs the EVAP system as I recall. It was also supposed to run the "TSAD" (Two Speed Accessory Drive) a "underdrive" pulley system that Ford anounced, but never produced.
   Rick
gblue
« Reply #4 on: May 14, 2007, 02:49:42 »
my computer is mounted on the passenger side carpeted firewall...just in front and  above of where you'd put your feet..gregg
« Reply #5 on: May 14, 2007, 04:20:09 »
Gregg,
   There is no OBD on your car, that came some years later. You can do a scan for basic codes with a simple meter.
   Rick
