Author Topic: CF9  (Read 53537 times)
J Jones
CF9
« Reply #91 on: June 05, 2010, 23:03:21 »
Beautiful! I really like the color (colour) -very elegant and purposeful. Also the wheels - They look like they belong to the car. Good cross between the original Chrome spokes and the Pin drive wheels of the big-block Cobras. Who makes these wheels?
   Emmanuel and I were visiting our cars at Dennis Cann's yesterday, and I looked at the wires of an original 289 Cobra - looked identical to mine. But those cars were considerably lighter than ours, so it's possible they might not be entirely adequate - depending on how aggressively one drives. Emmanuels car makes better than 500 hp and huge torque, so it's not inconceivable he could rip the spokes right off the hub. He's got pin drives now.
   Your interior is really nice, and is the same as my (old, and now a little tatty) early version. Where did you find the switches and window lift controls? Mine are the same, but missing some of the pictograms. (this information is probably in here somewhere. It would be nice if all the bits and pieces were listed in one place)
   Anyway - Good job!
Damien
CF9
« Reply #92 on: June 08, 2010, 22:08:05 »
The wheels were on the car when I bought it, and I had them polished (and new pins placed).  I think this are Wolfrace  wheels.
   The switches were also on the car, as you can see, two are not original, and I will have the originals copied.  The window switches come from an Aston Martin DB4 (this is as close to the original as I have found).
   As my car is also fitted with a 427 making around 400hp, my workshop guys have strongly recommended me not to go back to wire wheels.
   Kind regards,
   Damien
J Jones
CF9
« Reply #93 on: June 09, 2010, 01:46:17 »
I did find the correct switches online, but neglected to bookmark the page. Ridiculous! I'm pretty sure they were used on Maserati, but have forgotten which model.  So I'll have another look - but I did just find what I think are the decals that go on the switches.  here's a link:   http://www.cartype.com/pages/349/maserati_plaques_stickers_and_badges
J Jones
CF9
« Reply #94 on: June 09, 2010, 02:12:44 »
Damien
CF9
« Reply #95 on: June 09, 2010, 08:52:51 »
We have now tested the car and another problem arises.
   The original water hose leading to the water tank is higher than the water tank.
   This leads the air of the water tank to go into the engine when driven a little bit harder and that prevents cooling (at low speeds, there is no problem). The air indeed makes a kind of 'mayonnaise' with the liquid.
   How did you guys solve this issue ?
   Kind regards,
   Damien
Damien
CF9
« Reply #96 on: June 09, 2010, 21:54:50 »
I just had Moto Lita on the phone.  They indeed claim to have made the Cobra wheels, but not the Frua one (full wooden rim) and they cannot make it.  Has anybody an idea on who might be able to make it ?
   Best regards,
   Damien
Emmanueld
CF9
« Reply #97 on: June 10, 2010, 01:20:19 »
Hi Damien, do you have the original header tank and radiator? if not this would explain the problem. Can you send or post a pick of your engine bay. you may have to raise the header tank. Emmanuel
J Jones
CF9
« Reply #98 on: June 10, 2010, 04:43:34 »
Damien - I don't understand "photobucket", so I can't post a photo of my steering wheel, but it's different than Emmanuel's. Many bits on the car came from Italian suppliers. Who knows, really, how much of the interior was supplied by Frua? AC certainly had their own trimmers. The (by then) antique heating and ventilation controls were used by Aston Martin and other manufacturers (including AC) in the 1950's. I have a Bristol 404, with exactly the same unit. The switches on your car (and mine) were made by lucas, but used in Italian cars. The elegant chromed spiral springs that hold up my bonnet disappeared on later models. Did they run out of them? Was it an attempt to cut costs?
   The little AC company probably had to source parts from many suppliers over the 8 year period in which they managed to produce just 81 cars. There are significant differences between Emmanuel's car and mine. Economy and availability were no doubt big considerations for them.
   I looked for Alfa steering wheels - partly because Alfa parts appear on Fruas. Here's a link to an Alfa steering wheel, which is only slightly similar to the Moto lita Cobra wheels, but  the spokes are similar. Hub is different, but it's clad in black leather (as is mine), and has no rivets. Maybe the Wheel you are looking for is Italian. ?????????
   The "air in the cooling system" problem is a shared concern. I bought a new Flowmaster radiator, hoping it would help. Emmanuel has recently had cooling problems as well, thought to be a defective thermostat. But it could be due to air getting into the system. Emmanuel's car has a secondary overflow tank, which he thinks is "original". It is clearly a problem Ford was successful in solving in the hundreds of thousands of Big Block automobiles and trucks they manufactured, but a persistent problem for Frua's.
   Here's the link to the (incorrect) Alfa steering wheel.
   http://cgi.ebay.com/ebaymotors/Alfa-Romeo-Giulia-Spider-Sprint-Steering-Wheel-/120581284229?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item1c13346185#ht_500wt_911
administrator
  • Administrator
CF9
« Reply #99 on: June 10, 2010, 08:12:02 »
If you have problems posting photos,email them over and I will put them up for you - bryan dot mo at btinternet dot com.
Damien
CF9
« Reply #100 on: June 10, 2010, 09:17:14 »
Thanks for the input.  I will put a Cobra steering wheel on my car until I find an original one.
   Concerning the heating, the technical solution is easy.  The water tank needs to be put higher than the whose leading to the engine, so the air stays in the water tank.  The problem of the AC is that the bonnet does not allow that at the place the water tank is.
   With my new radiator, the cooling liquid is at 95°C at the top and below 80°C at the bottom, which means it works perfectly.  When driven harder however the air is sucked into the water hose, mixes in tiny bubles with the coolant, creating a kind of mayonnaise that does not do the cooling job any more.
   I will look how I can solve it technically.
   Best regards,
   Damien
Emmanueld
CF9
« Reply #101 on: June 16, 2010, 23:23:18 »
Damien, my steering wheel is 15.5" OD, just get a cobra wheel and modify it to look like a 428 wheel. I am going to remove mine an install a Moto-Lita as soon as I get the hub. I will send it to be refinished. This is just a temporary thing, I am not changing the wheel! [:)]Emmanuel
Michael Trotter
CF9
« Reply #102 on: July 27, 2010, 21:20:21 »
Damien, it's looking very impressive in the photos - congratulations. Is the paint Guardsman Blue? Do remember not to have your head under the bootlid on a windy day - an AC design error in my view to put the lower pivot of the gas strut too near to the line of the hinge pins. On CF6 I moved the pivot pin down and further back and a longer strut holds the lid against a wind and assists the opening of the lid. What are the 'small black handles' on the dash you were looking for?
   Re your cooling/air in the water concerns - I assume your header tank is the original or repro Serck rectangular tank mounted so it slopes down to the front and the front pipe stub is in line with the rad stub. You are right that air bubbles circulating in the water are a BAD THING. Air in the water reduces heat transfer in the radiator, may cause local boiling in the very hot parts near the exhaust valves and at high rpm may encourage cavitation in the pump inlet. I reckon the capacity of the header tank is about 4 pints(Imperial) and the expansion of the CF6 system from cold to hot is normally about 2 pints but has been to 2 1/4 ; let's work on 2 1/4 pints. If your header tank were full when hot with no air in the system then when cold it would have drawn in 2 1/4 pints of air. The inlet and outlet pipes will be uncovered and air will go into the circulating system at the next start. So I think your problem is lack of an expansion tank rather than height of tank or hoses. A single header/expansion tank can work but it needs to be bigger and higher than the rectangular Serck and preferably not part of the circulating system.
   Apart from CF1 I think all 428's probably have an expansion tank in addition to the Serck header tank. With this setup the header tank has a plain cap sealing on the top lip of the neck, the pipe from the neck to the expansion tank is pressurised and has hose clips and the expansion tank has the 13psi pressure cap. All 428's I have seen have a black painted expansion tank with a distinctive kidney shape taken from BMC 1300 and 1800's of the 60's. I think this was a design error because the tank has a volume of only 2 pints and the feed pipe which goes in from the side stops 1/4 pint from the bottom so it can only cope with up to 1 3/4 pints of expansion without dumping water on the road and/or drawing air back to the header tank on cooling down. I think it can just about work without topping up but the cold levels would be 1/4 pint of water in the bottom of the expansion tank and 1/2 pint of air in the header tank some of which might get circulated. I found this impossible to judge and could never resist the temptation to top up both tanks. In the discussions about 'overheating' I haven't seen any reference to topping up and wonder how much of this other owners do.
   I replaced the original expansion tank with a BMW tank which is translucent plastic, designed for 13psi, has a neck which takes the original AC-Delco cap, is a suitable shape and can just cope with 2 1/4 pints of expansion. I mounted it on the RH inner wing panel above the alternator/front end of the rocker cover and have a cold level line on it so I can check this without removing the cap. The header tank is completely full hot and cold. Since 2004, doing 2 or 3 thousand miles a year I have topped up only at the end of the season when it will need about 1/4 pint to restore cold level which I think reflects coolant loss from pushing damp air out and drawing dry air back in.
   On the road indicated temperature, depending on ambient air temerature, is 80 to 90C (88 to 93 true).The electric fan switches on/off at 115/102 indicated (103/99 true at the sensor) in slow traffic and idling. The Otter thermoswitch in the header tank for the fan makes at 90 and I have a manual switch in parallel and a 'fan on' warning light so I can switch the fan on before I reach a traffic jam.This all seems to work OK and I think you should not worry about the number the needle points at if no topping up is needed because, by definition, it has not overheated or lost water.
   For those still reading this I add a few general points. Discussion of 'overheating' has focussed on water, engine bay and car interior temperatures. On the water temperature issue I think the larger expansion tank is a good start plus: 1. Cure all water leaks - even a small one will lose significant water with hot 13psi water behind it over time.2. Pressure cap valve lift at 13psi is vital to maintain system pressure and is worth checking regularly. At 13psi water boils at about 117C and this is important to maintain a safety margin over water temperature. 3. Fit a big fan. I have a 16" Kenlowe; it pulls 21 amps but shifts 2320 CFM in free air and about 1900 CFM installed - still only about the same as 15mph. The matrix of my radiator is 19.5" wide x 17.25" high x 2.75" deep. Is this a typical size? 4. I think you must have a thermostat to get a fast warmup and reduce engine wear which is dramatically higher at low temperature. I reckon opening at 74C and fully open at 86C is about right in the UK. 5. For most of us who see highest temperatures at idle/low speed an aluminium Edelbrock water pump is worth considering. They claim higher, but unquantified, flow rate at low rpm and I was prepared to believe this having seen the crude 'paddle wheel' impeller in the original Ford pump which also weighs a ton. 6. With a header tank always full there is a case to eliminate it.I think the Cobra Mk1V has a header/expansion tank with a system filler in the pipework at the highest point. I kept my header as it's a convenient place for the Otter fan switch and I thought the internal baffle directing the water flow under the filler neck would capture any air bubbles (inevitable when you have drained the system).
   So far as engine bay temperature is concerned I didn't like the fierce heat which hits you when you open the bonnet after a fast run and in years of motoring the 428 is the only car in which I have experienced fuel vapourisation. I think you should have a minimum of fuel pipework in the engine bay and insulate it where you can. I fitted 2 extraction fans to draw air out and through the side vents which seem otherwise to be more decorative than functional.These shift 1200 CFM of air total and lowered the engine bay temperature by about 6C on test with no noticeable effect on water temperature. However this modest reduction takes some of the sting out of the heat and I think has avoided fuel vapourisation which has only happened at idle/low speed. Incidentally I don't understand the aerodynamic theories we have heard and the talk of bonnet louvres. Whilst I would expect louvres to lower engine bay temperature I doubt they would have significant effect on water temperature except perhaps at very high speeds. I wouldn't want to change the lovely lines of the car but if you were to add bonnet louvres I would have thought 1/3 to 1/2 way back from the front end would be a low pressure area to put them whereas the rear end of the bonnet just ahead of the screen is a high pressure area - isn't that why modern cars have their interior heating/ventilating air intakes there? And is there evidence that an Aceca with louvres runs cooler than an Ace without but otherwise the same ahead of the screen?
   So far as excessive heat in the interior is concerned I think the solution is don't drive a fastback, do drive a convertible with the soft top down, don't drive in California, don't have an auto, do have good footwell fresh air from the fans at the front end with the ducting going above the front wheels outside the engine bay and, if all else fails, follow Emmanuel's advice on heat insulation to isolate you from that 7 litre space heater!
   I hope Damien that you (and others) may find some of this helpful and that it may elicit other/differing views and experiences. The 428 is a super car and I hope you get as much enjoyment and fun out yours as I have from mine.
   Michael
cliffordl
CF9
« Reply #103 on: July 28, 2010, 11:25:43 »
All sounds like good advice to me. CF25 runs a large aluminium rad and edelbrock water pump but original expansion tank. In the current hot weather even with roof down my feet get heated so I guess one day I'll get around to an Emmanuel style heat proofing exercise still it's nice in the winter. The water temp was getting over 100 degrees so on the advice of Thunder Road I added 'water wetter' which has dropped things by a good 10 degrees or more.
   BTW Thunder Road did a great job for me on sorting out some rather dodgy old electrics and fitting Hawk Cars new shocks along with a  complete suspension refurb/re-bushing. Getting to the point where the car is almost reliable..
   Oil temp still goes well over 100 degrees so a cooler is next on my list of improvements.
   Happy motoring
   Cliff.
Emmanueld
CF9
« Reply #104 on: July 28, 2010, 22:42:32 »
Michael,
   I agree with what you wrote with one exception. The configuration of the header tank and recovery bottle. The pressure cap has to go on the header tank at the highest point to let the air escape and the recovery bottle down below must have a non pressured cap. Otherwise, you will have trapped air in your system and loose too much coolant. My car still has its original radiator which has been cleaned and runs cool below the 90 degrees mark. The electric fan has been replaced by a much larger one. I drove it in 110 degrees heat a week ago and although it ran hotter than usual, it was steady at about 100 degrees in traffic and back to 90 on the highway. Remember, the engine is a 454 cubic inch which generates more heat than a 428. The car has a 5 speed box and the gear ratio is a bit long despite the 3.08 conversion. I think the perfect compromise will be 3.31 with that gearbox. We were able to install the gearbox without any major modification to the car so all is well. It was basically an easy swap. The heat inside the car is now tolerable but I need to take it for an afternoon drive to know for sure.
   I am planning on adding some openings on the hood to let the hot air escape, Probably like on the Ferrari Daytona or the Maserati Ghibli. A hood scoop like on the 427 Cobra would work well for cold air intake, but we have to see if it will work with the car design.
   Emmanuel [:)]
