Author Topic: MK1v Door hinges  (Read 2452 times)
Baz
MK1v Door hinges
« on: April 28, 2020, 14:21:05 »
any one know where the door hinges originally  came from or did Autokraft make them mine are getting a bit sloppy regards Baz
Re: MK1v Door hinges
« Reply #1 on: April 28, 2020, 21:24:45 »
Door hinges are fabricated, massive steel parts and not from other production cars. First check the door bolts / pivot pins. You need to remove the covers between door and instrument panel kept by 2 screws.  One small screw is on the top of the cover visible from below, the other one is covered by the carpet below the door hinge.
« Last Edit: April 28, 2020, 21:55:17 by westcott »
Baz
« Reply #2 on: April 30, 2020, 19:06:09 »
once again thanks for help Baz
