Author Topic: Cockpit shower cover  (Read 2366 times)
Clive Austin
  • AK1318 AC MKIV 7 litre
« on: March 15, 2020, 16:27:50 »
Way back when I had an MGB I had a light weight cockpit shower cover that fitted over the windscreen and cockpit to protect it through a shower without putting the full roof up.  A sort of "pac-a-mac" for cars.  Being light weight, it packed away into a small bag and took up virtually no room in the boot.  Has anyone come across anything similar for Cobras?  Tricky given the roll bar but not beyond the imagination of a suitable manufacturer - even if it was a custom cover.  Has anyone come across such a thing?
C
Clive Austin
Re: Cockpit shower cover
« Reply #1 on: March 16, 2020, 08:59:56 »
Clive,
what is the advantage of a cockpit shower cover compared to a tonneau cover, which is standard for the MK IV?
1985 CCX
« Reply #2 on: March 26, 2020, 14:45:58 »
Clive
Is this a tonneau cover?  You can get a cover that will work around the roll bar.
Needs pics?  You make cuts that either overlap and use Velcro or zipper....
« Last Edit: March 26, 2020, 14:54:35 by 1985 CCX »
Jeff Gagnon
AC MKIV #1085 and CSX2375r
GagnonJeffreyS@gmail.com
