Author Topic: Thermostat Housings  (Read 5877 times)
Thermostat Housings
« on: February 10, 2020, 17:23:54 »
Just a note to those owners needing a new Thermostat Housing, i have these now available, they are made to suit modern thermostats which have heat Ranges from 68 degrees Centigrade Up.
If you need information please contact me!
Big col
Re: Thermostat Housings
« Reply #1 on: February 12, 2020, 21:25:24 »
Hello Robin, am I right in presuming that the housings are for the later engines rather than a modification to the pre war ones.
« Reply #2 on: February 13, 2020, 08:51:01 »
Col
Yes these are for Post War engines for the 2-litre saloon, Ace & Aceca fitted with Weller engines.
pjbowman
« Reply #3 on: June 04, 2020, 02:02:46 »
Robin, sent you a PM regarding one.
Peter B.
PaulAnderson
« Reply #4 on: August 14, 2021, 07:25:51 »
I have bought one of these from Robin for my ACE and they are great. Perfect fit that takes modern racing thermostats.
AndyN
« Reply #5 on: August 14, 2021, 10:15:16 »
Hi Robin is it just the housing or do you have the 2 litre top hose connector too?
« Reply #6 on: August 14, 2021, 11:01:17 »
Andy
I have a couple of the 90 degree type which are AC New Old Stock!
I have casting patterns made to make more of these with extended length for hose connection, i understand both of these are to suit Ace & Aceca's
You could possibly adapt the rubber hose for use on 2-Litre cars.
