Author Topic: Windscreen interior vertical trims.  (Read 604 times)
AcemanToo
« on: January 26, 2020, 10:05:20 »
Next question!
The interior windscreen trims, the ones at either side that are covered in Alcantara - does anyone know how they are attached and how to remove them please?
ACECA-ACE
Re: Windscreen interior vertical trims.
« Reply #1 on: February 08, 2020, 13:03:24 »
The ones I have taken off were glued, not found clips. It will be GRP so quite strong, becareful not to bend to much. I hope this helps.
AcemanToo
« Reply #2 on: February 11, 2020, 10:46:21 »
Many thanks for that? Mine appear to be made of steel covered in a thin foam layer then finally covered in alcantara. The alcantara has worn through at the edges and the underlying steel has rusted. I can't see any signs of GRP so maybe AC used a different material for the Ace Aceca. The joys of AC ownership....!
