Author Topic: Sunburst wheels on MKIV  (Read 5653 times)
1985 CCX
« on: December 27, 2019, 02:05:09 »
New project
Add Sunburst wheels to my MKIV
The trick will be to retain the original exhaust ......
Offset and tire size will be key
Planning Goodyear Power Cushion
Newly cast wheels
Jeff Gagnon
AC MKIV #1085 and CSX2375r
GagnonJeffreyS@gmail.com
1985 CCX
Re: Sunburst wheels on MKIV
« Reply #1 on: December 27, 2019, 02:07:10 »
Newly cast wheel
Jeff Gagnon
1985 CCX
« Reply #2 on: December 27, 2019, 02:15:57 »
The Power Cushion
« Last Edit: December 27, 2019, 02:23:30 by 1985 CCX »
Jeff Gagnon
« Reply #3 on: December 29, 2019, 14:37:25 »
Gary's Sunbursts I assume.
What backspace do they have?
« Last Edit: December 29, 2019, 15:16:25 by westcott »
1985 CCX
« Reply #4 on: December 29, 2019, 18:35:31 »
Yes
I’ll have to go measure.
Think the same as the 60’s car as I have one of those too
With narrower tire should allow it to work?
I’ll put the wheels on this weekend
Jeff Gagnon
1985 CCX
« Reply #5 on: January 04, 2020, 01:25:53 »
Ok, roadblock
With the current exhaust the sunburst gets tire within 1” of the SS muffler.
The FIA allows for the same 1.5” that the MKIV wheel does.
Will need to do more measuring but may use mag FIA ?
15” fills wheel-well out nicely.
Thoughts?
« Last Edit: January 04, 2020, 01:30:43 by 1985 CCX »
Jeff Gagnon
1985 CCX
« Reply #6 on: January 16, 2020, 02:40:11 »
Magnesium FIA
Just need the sneakers
Jeff Gagnon
« Reply #7 on: January 16, 2020, 13:42:31 »
I expected the closer distance from rubber to exhaust with the Sunbursts, therefore i asked for the backspace.
That problem is not existing with the real 427 street exhaust routing were the axle loop is partially inside the cutted trunk tub and covered with the always visible covers inside the tub.
In addition to the FIAs I would suggest to mount nothing bigger then 255 at the rear. With my 275 rear, even with deleted resonators and re routed exhaust tube loop the distance on the rh side is quite small. So wrapping with good wrapping tape is necessary.
Next time I need to replace my rear tires (and that will happen soon with the AVONs)  I will switch from 275 to 255.
1985 CCX
« Reply #8 on: January 16, 2020, 20:25:46 »
Correct not much room under the fender.  I already have a typical Cobra with race wheels etc so my choice for tires is Goodyear Power Cushion in pics above.
They were the street tire in the 60's and will handle well, as I am a stock 225hp stability should be fine.
Will plan to wrap exhaust as dropping the under fender heat can only be a good factor for tires, alloy body and paint.
Jeff Gagnon
1985 CCX
« Reply #9 on: March 19, 2020, 00:46:46 »
Drives 100% better.
Rides better
Hugs the road, differently but nice.
Very happy with the choice.
Magnesium FIA 6.5
Goodyear Power Cushion 775/15
https://www.youtube.com/watch?v=n0m4rKsTQkc
« Last Edit: March 23, 2020, 17:38:55 by 1985 CCX »
Jeff Gagnon
1985 CCX
« Reply #10 on: February 28, 2021, 18:27:52 »
Updated picture from last Spring 2020.
Ready for winter to end....
Jeff Gagnon
