Originally posted by GaryC
Keith....I have two Borroni wires that came with the Ace. I believe they are 16" and are alloy....are these stronger than the stock and if I dont use them, what's a reasonable amount to ask for them. They need restoring (polishing etc). I also didn't notice any specs for tighting the "knock offs"...would that be three hard hammer swacks with lube?? Gary
Borroni wheels have ali / alloy rims, which gives you a reduction of unsprung wieght, Any weight loss on a Ace used for competition can only help keep our cars competitive, Astons, Healeys and XKs seem to be gaining BHP like its going out of fashion, whilst the Ace is loosing ground.
Borroni wheels are now being remanufactured, pending on size " Dia, Width, and offset will determinethe cost of a new wheel. Not sure of a 16" new one, but wouild guess in the region of £850.00 each give and take £50.00.
Second Hand Value is down to Supply / demand and off course condition, Not really the best time to sell with the so called Credit Crunch, keep them for a while then advertise in ACtion or on ebay. There is a good market for good S/H units.
Regards torque setting for spinners, I tend to use a copper hammer-mallet until I know they are tight, after which they continually tighten as the wheel revolves ( Hence the marking indicating there handing). I always regularly loosen off each spinner and then retighten, it has been known to be a real bugger to get some spinners or large centre nuts undone after many months often resulting in shearing off the odd ear .... Frustrating to get a broken spinner off and bloody expensive to replace.
To use lubricant or not
some do some don't, I tend to use a light smear of copper grease but not sure if its the right thing to do.. .. Polite suggestions only ... thank you.
