Author Topic: Ace Bristol horn location  (Read 2161 times)
bertalanffy
« on: August 28, 2019, 18:13:26 »
I could not find any fotos of an engine bay that show the location of the two horns of the AC Bristol. Could someone please tell me where they were originally mounted. Fotos would be great. Thank you
Re: Ace Bristol horn location
« Reply #1 on: August 29, 2019, 08:50:27 »
Bertalanffy
The two wind tone horns are located under the Aluminium nose hidden by the radiator, Should be visible if you look  up through the grill.
You can just. see them if you look over the top of the radiator, one either side of the radiator cap and the bonnet hinge.
« Last Edit: August 29, 2019, 09:10:22 by AC Ace Bristol »
« Reply #2 on: August 29, 2019, 18:25:51 »
I don't know whether is a difference between an Ace and an Aceca. Here you can see the position in an Aceca.
At the bottom you see the radiator, on the top it's the nose. On the left side you can see a hinge of the bonnet. Maybe it helps a little bit.
bertalanffy
« Reply #3 on: August 29, 2019, 19:36:10 »
Thank you for the replies, now I know where it has to be.
