Author Topic: Clutch Quadrant Replacement  (Read 12497 times)
jmohara
  • Owner of AK1099
« on: August 26, 2019, 23:05:26 »
I am going to embark on this as its making some odd noises down there!
I know there are threads on this, but some of the links have expired.
I am looking for any detailed instructions to do this on our cars - it's a tight space! Do you need to remove the pedal box to do it right?
Any help much appreciated!!!!
Michael
1985 CCX
Re: Clutch Quadrant Replacement
« Reply #1 on: August 27, 2019, 18:28:35 »
I assume this is a master or slave change?
Only have performed this on a std 289 car.  Usually held in place and easily changed out.  Add pictures as it helps us help you.....
Jeff Gagnon
AC MKIV #1085 and CSX2375r
GagnonJeffreyS@gmail.com
jmohara
  • Owner of AK1099
« Reply #2 on: August 27, 2019, 21:03:17 »
Plastic quadrant on the clutch pedal. A lot of people change it for a steel replacement....
There were threads on how to do it but they are dead links now.
« Reply #3 on: August 29, 2019, 10:38:02 »
Hi Michael,
you can do it in the car but the easiest is to remove the pedal box.
The pedal box is held in front of the car by 2 nuts to the bolts of the brake booster and on top by to other nuts.
Remove the nuts and You can remove the pedal box but before:
- removed the clip from the brake booster rod visible on the brake pedal from the rear
- disconnect the nutral safety switch and brake light switch
If I remember correctly the quadrant is from a period Sierra and is color coded, ours shoud be white.
Unfortunatelly I lost all my notes on spare part #s because of pad malfunction and had no backup....
An example of a complete repair kit is here:
https://picclick.de/Ford-SIERRA-MK1-MK2-Kupplung-Pedal-Nachsteller-RS-112581082944.html#&gid=1&pid=1
Don't click on details, the offer is not longer available, just take it as generic pics for the parts you normally need to repair the clutch pedal adjustment.
I will check my parts bin this evening for part numbers if nobody else is responding in between.
« Last Edit: September 01, 2019, 15:21:08 by westcott »
jmohara
  • Owner of AK1099
« Reply #4 on: August 29, 2019, 18:15:56 »
Hi Uwe,
As usual you are a legend.
My brake lights are activated by a switch on the brake lines and I dont have a neutral safety switch so all good.
I am going to use an aluminum replacement - and just manually adjust.
Did you have to take the steering column out or did you work around it?
M
« Reply #5 on: August 29, 2019, 19:29:40 »
The pedal box is left from the column and goes out with the column in place.
In the 80s Ford sold racing clutch pedals with quadrant adjustment by a set screw so the manual  adjustment is a common improovement.
The aluminum quadrants sold in the US for the mustang will not fit,  the diameter/radius is too big.
The radius must be 50mm to work in the assembly.
Here you see the tech specs and Ford part #:
http://www.fordopedia.org/parts-catalog/sierra-mk1/D2.10
The numbers are: 83BB-7L583AA and G82520 on the quadrant
« Last Edit: August 29, 2019, 20:15:22 by westcott »
jmohara
  • Owner of AK1099
« Reply #6 on: August 29, 2019, 22:27:10 »
Awesome info thanks!
jmohara
  • Owner of AK1099
« Reply #7 on: August 29, 2019, 23:24:32 »
There must be a 50mm alloy one out there somewhere! Anyone?
« Reply #8 on: August 30, 2019, 11:35:29 »
This could be a project to make some 50mm ones if no ready made alternatives surface.
I have not been a victim of the plastic quadrant thru breakage but got caught out by the automatic adjustment so would prefer manual, though I now know all about resetting the quadrant after fitting a new clutch cable.
Kevin C
« Reply #9 on: August 30, 2019, 12:55:32 »
Touch wood I have never had to replace mine, so have no personal experience to share, but it may be worth chatting to:
http://randbmotorsport.co.uk/shop/Details.asp?ProductID=386
https://shop.grahamgoode.com/clutch-cables--quadrants-21548-c.asp
« Reply #10 on: August 30, 2019, 17:13:08 »
Kevin,
Thas useful info and I have dropped R&B an email.
The issue may be that an adjustable clutch cable will need to be made up also.
jmohara
  • Owner of AK1099
« Reply #11 on: August 30, 2019, 18:47:47 »
Not cheap!
« Reply #13 on: August 30, 2019, 21:03:08 »
jmohara
  • Owner of AK1099
« Reply #14 on: August 31, 2019, 21:56:03 »
Hauled the peddle box out and for sure the quadrant is stripped. New plastic one ordered.
Uwe - where on the adjusted did you set it on install?
M
