Author Topic: Gear lever disassembly  (Read 1299 times)
IanBrown
« on: May 02, 2019, 19:40:09 »
I have removed the gear-lever assembly from my car. I have pushed out the locating pin that passes through the white ‘nylon’ ball. I can slide the ball down which then exposes a metal collar Am I correct in assuming that the collar should slide up the gear-lever towards the gear knob?
If so, any idea how to get a stubborn one off?
« Last Edit: May 02, 2019, 19:54:29 by IanBrown »
  • Administrator
Re: Gear lever disassembly
« Reply #1 on: May 06, 2019, 15:58:01 »
From Ian Winter:
Yes, the metal collar and bush should slide off of the top of the
gear-lever.  If  it's a bit tight then I'd have thought a few taps
around the circumference of the collar with a small punch should drift
it off.  I guess you could try a small amount of heat on the collar also
but be careful to protect the nylon bush if you plan to reuse it else it
may melt. Interestingly, your bush must be someone's replacement item as
these are from the Hillman Imp and originally black in colour.
You might wish to replace the bush and collar with the harder material
bush that Malcolm Anderson (Imp parts) supplies, as these should last
longer. see http://www.malcolmanderson.co.uk/sparesct.html
