Author Topic: AC MKIV Brakes parts and pads - Help needed  (Read 5595 times)
cobra06FR
« on: April 30, 2019, 21:05:12 »
Dear All,
I need to change the brake pads of my rear brakes on my AC Autokraft MKIV 1989. I have no idea what brand they are nor where to buy them from.
could anyone advise me on "what" and "where" to get them from.
In addition looking at my two rear brake systems I realised that actually there is a small part missing on one of them. It is the upper metal plate that seems actually to "seems" to keep the pads away from each other OR possibly avoid some vibration of the pads ? (see picture attached).
Again if anyone could tell me what this metal piece is for and advice where to get and buy it, I would very much appreciate.
Many thanks in advance for your help
Best Regrads to all
LaurentCobra06
Many thanks
Best Regards
L
AC Ventura
Re: AC MKIV Brakes parts and pads - Help needed
« Reply #1 on: May 02, 2019, 14:12:08 »
I have AK 1500 1993. Front pads I have here are PAGID (Germany) T0494. I bought them in the UK from Euro Car Parts. I'm sure I have the rear number somewhere.
lightblue
« Reply #2 on: May 02, 2019, 14:50:06 »
Hi Laurent,
It's difficult to make out from the picture but I guess these are the Peugeot 504 calipers.
Not sure if the part no's are current but pads were listed variously as Ferodo FG258, FG463, FDB71 and Mintex MGB560.  Ferodo also suplied Fitting Kits (which included you missing spring-plate plus pins) as FBA408.
Hope this helps.
John.
jmohara
  • Owner of AK1099
cobra06FR
« Reply #4 on: June 12, 2019, 16:06:46 »
Many thanks to all of you John, Ac Ventura and M.
Very usefull infos. I have the pads now.
All the best
L
Many thanks
Best Regards
L
« Reply #5 on: June 13, 2019, 11:29:31 »
Hello Laurant,
the metal spring plate will avoid vibrations and the typical sqeek we hear sometimes with other cars if the brakes are just slightly activated.
1985 CCX
« Reply #6 on: September 06, 2019, 01:22:06 »
Did these pads work?
Jeff Gagnon
AC MKIV #1085 and CSX2375r
GagnonJeffreyS@gmail.com
1985 CCX
« Reply #7 on: September 06, 2019, 18:48:14 »
Anyone have thoughts on this caliper?  Appears different than the ones described...
Jeff Gagnon
« Reply #8 on: September 07, 2019, 13:39:45 »
I would un bolt it and check for clues. The picture at the beginning of the thread is hard to see to compare.
jmohara
  • Owner of AK1099
« Reply #9 on: September 08, 2019, 02:04:00 »
Thats the Peugeot 504 caliper. Same as my car.
1985 CCX
« Reply #10 on: September 09, 2019, 00:30:47 »
Awesome thanks
Jeff Gagnon
