I have the unit installed now. The car is running fabulous. great improvement over the original, worn out distributor. No misfires, immediate starting, very little need for choke on a cold start, smooth running, excellent fuel burn. It is really a great improvement. I was at the end of what I could tweak with carbs/mixture and without any changes to those, adding this distributor made all the difference. I will post the settings I have it on soon. I do have a slightly hotter cam than stock from Robin Woolmer and possibly a slightly higher compression ratio than stock with the rebuilt rotating assembly. So if you are looking for replacement of your distributor, I can definitely recommend this one. Thanks, Robin, for hooking me up!!
Gus
