Author Topic: Replacement Battery  (Read 3179 times)
twogreens
Replacement Battery
« on: March 23, 2008, 20:35:49 »
The battery in my Mark IV has given up the ghost in the winter weather.  Does anyone have any recommendations for a good replacement?
   Regards to All
   Two Greens
Replacement Battery
« Reply #1 on: March 23, 2008, 21:12:54 »
If available in your area..Optima...never needs care, relatively compact ..good cca. Jim
Jan_AC_MKIV_1227
Replacement Battery
« Reply #2 on: March 24, 2008, 18:07:26 »
Hey Two Greens,
      I installed an Optima red top and in the winter start the car once a month, the optima has never let me down, a great battery.  WE NEED WARM WEATHER, I miss driving the car..
   Jan
Replacement Battery
« Reply #3 on: March 24, 2008, 18:40:22 »
You might wish to consider an alternative battery by Hawker which is the 'Odyssey' range which are available in USA & UK, i use these on my Massey Ferguson tractor as well as modern cars, they have a very high cranking ampere rate & do stand long storage & multiple deep discharging offering significant life.
   Odeyssey PC925 is £106 +vat in UK & i believe lower in USA, the PC1200 is £123 +vat the number equating to the cranking amps for 5-seconds.
   look on web site ' www.active-robots.com ' in UK & there will be an equivalent one in USA, this site gives the specifications & dimensions.
   I will not buy ordiary batteries ever again.
   regards
runt
Replacement Battery
« Reply #4 on: March 24, 2008, 19:04:54 »
And; definitely invest in an 'Accumate' charger; these will whack your battery round to 13v even if really low, well worth the money.
   Paul/runt.[:)]
Replacement Battery
« Reply #5 on: March 25, 2008, 17:20:55 »
Best Battery charger to suit the Odyssey bateries is CTEK XS3600 @ £48 +vat or CTEK XS7000 @ £84 +vat & can be supplied by Active-Robots also!
   Very versitile to use & will do maintenance duty in the winter months.
Baron Samoth
Replacement Battery
« Reply #6 on: July 29, 2008, 23:41:16 »
Hi Fans
   The most important thing to remember, there is no such thing as a "Maintenance Free Battery" unless it is gel filled. It is worth devising a method of checking the electrolyte level even despite the difficulty on a MKIV CRS. Over the years (50) I have found all batteries need routine maintenance.
   The Baron
