Author Topic: Headlight conversion  (Read 2518 times)
AK1246
« on: September 24, 2018, 17:00:48 »
Dear all
As a new forum member first I want to say hello to you all. I`m living in the south of Germany and love the cobras since the `90 when I watched them racing on the Nürburgring. But the main thing is I`been happy owner of AK1246 for a few days.
AK1246 is a UK-version so I have to convert the headlights for driving on the right in Germany. Is there a how to for dismantling the headlamps or a short guide?
Thank you in advance for your assistance.
Juergen
Re: Headlight conversion
« Reply #1 on: September 24, 2018, 22:34:29 »
Hi Juergen,
remove the clipped big outer chrome ring from the headlamp assembly, starting at the lowest point.
If someone replaced the headlamp bowl/complete unit by a screwed version instead if the clipped one , remove the possible single  screw at the lowest point of the big outer chrome ring
Remove the 3 screws keeping the small inner chrom ring in place.
Remove the small chrome ring together with the reflector/headlamp insert.
Take care, after you remove the last of the 3 screws keeping the small chrome ring,  both parts (ring and glas) can fall down......
Insert a continental glas unit, attach the small chrome ring with the 3 screws.
Adjust the headlights or let a workshop adjust them using the two adjustment screws.
Assemble the big outer chrome ring after adjustmeht is done
Uwe
AK1246
« Reply #2 on: September 25, 2018, 10:02:02 »
Hi Uwe
Many thanks for your how to. I appreciate it very much.
Have a good day.
Juergen
