Author Topic: New Dynamo for Aceca Bristol  (Read 2702 times)
Nicola
« on: October 24, 2007, 10:02:32 »
Hello,
   I am completely new to this forum. Since July I am the owner of an Aceca Bristol 1958 (BEX 652) and now the dynamo has given up on me. It is appearantly completely broken and I am thinking of buying a replacement. Where can I get one? Thanks for helping.
   Best
   Nicola
« Reply #1 on: October 24, 2007, 11:15:20 »
Hi
   You could try the following two people who re-manufacture & probably can repair your existing unit both in UK
   Classic & Vintage Dynamos Tel/Fax 44 1623 747666
   or P&J Autos  44 1708 500010 or 44 1708 500011 fax 44 1708 500012
   You might find you only need new brushes so you could simply replace them & give it a clean.
« Reply #2 on: October 25, 2007, 18:26:21 »
Additional information-
   Moss Europe sell/recondition Dynamo's C39 & C40 Type & have 20% discount this week end.
   No i am not on commission!
Nicola
« Reply #3 on: November 05, 2007, 11:21:10 »
Thank You for the tip. I will contact Moss Europe. Do any C39 and C40 type dynamos fit?
   Nicola
« Reply #4 on: November 05, 2007, 13:07:01 »
Nicola
   The Lucas Spec sheet for the Aceca suggests the correct dynamo is the C39, i believe the C40 has slightly larger body but probably will fit!
   Why not consider fitting An Alternator, more expensive but much more output for winter driving.
