Author Topic: Ace/aceca fuel sender info needed  (Read 1803 times)
ivs
« on: February 14, 2018, 03:24:01 »
Hi,
Was the Smiths fuel sender used in other british cars of the same era? Does someone have a rebuildable one for sale?
Ignacio Vivancos
Austin, TX
ivivancos@austin.rr.com
Re: Ace/aceca fuel sender info needed
« Reply #1 on: February 14, 2018, 09:42:34 »
Hi not sure how old you car is, however if the sender is the type with the 6 holes and a cork gasket that fit to the tank then an early morris minor/mini/MGA are all similar you may have to bend the float wire a bit to suit the the tank depth. There is also the type that fit on a flange style this with a gasket and a clamp bit as per MGB and later minis minors etc.
Hope that helps, you can get them over here for approx. £25-30.
Cheers  Gary
