Author Topic: Brake light pressure switch  (Read 3288 times)
jmohara
  • Owner of AK1099
« on: September 30, 2017, 20:38:54 »
I have a little pressure switch in the drivers rear arch that activates the brake lights. Seems to have failed. Anyone know the part number or the source of the original part?
silty
« Reply #1 on: October 01, 2017, 14:25:47 »
Very high tech!   I have a mechanical switch mounted on the brake pedal arm.
   Like you, I'd try and get the original part but if that proves to be elusive retrofitting a simple on/off switch to the brake pedal may be an easy alternative OEM option for you?
Mark IV
« Reply #2 on: October 12, 2017, 22:21:59 »
John,
   Local Ford dealer. Part number C1AZ-13480-A or Motorcraft SW24. Don't use cheap ones, they split and leak.
jmohara
  • Owner of AK1099
« Reply #3 on: October 15, 2017, 13:41:48 »
Thanks Mark IV. Got it. it didn't have the same brake fitting on the end, but sorted it all and its working nice!
