Author Topic: Rear hubs needed, urgent....  (Read 3309 times)
« on: July 16, 2017, 17:32:01 »
The only thing i did not check 2 years before during my MK IV rebuild was the rear hub assembly on my MK IV.
   Now, I think on the Silvretta high alpine road, it happened, the lousy thin shims between the wheel bearings and spacer gave up, a quite big endplay in the bearings caused the outer cone to walk around on the hub.
   The right hub is worn out where the outer bearing cone sits and need to be replaced.
   Does anybody know who in the UK has the MK IV hubs in stock ??
   I highly appreciate every support.
   We planned a Cobra holiday in Italy for the first week in September enjoying good wine and food in the Barolo area.......hopefully with the repaired car.[:0]
« Reply #1 on: July 16, 2017, 17:37:37 »
Gerry Hawkridge?
« Reply #2 on: July 17, 2017, 00:49:36 »
   Westcott
   Alternative to Gerry  Try  Steve Gray :-
   Tel:  44 (0) 1932 828 545
   mob:  44 (0) 7860 912 217
   www.brooklandscarsltd
« Reply #3 on: July 17, 2017, 10:38:12 »
And last but not least Jonathan Bradburn http://www.jbradburn.co.uk/index-2.html
« Reply #4 on: July 17, 2017, 13:24:49 »
Jonathan directly told me to get in contact with Gerry. Steve got some mail with information. I will keep you updated.
« Reply #5 on: July 19, 2017, 12:26:03 »
left rear hub looks ok but the centre screw started to get loose.....
MkIV Lux
« Reply #6 on: July 19, 2017, 17:41:18 »
Hi Uwe,
   I sent you an e-mail.
   Cheers
   Constant
