Author Topic: Carb or ignition?  (Read 3067 times)
mdonegan
Carb or ignition?
« on: June 29, 2017, 16:55:53 »
My 428 refuses to rev past 3750 rpm!  i replaced the holley which was warped with an edelbrock on the advice of Peter Knight with no improvement. so have now replaced fuel lines and fuel pump but problem still persists.  I have had the car on a rolling road to try and determine the cause without success.  it pulls strongly until the revs reach 3750 and then backfires and dies - does anyone have any ideas of where i need to go next in tracing the problem?
david langford
Carb or ignition?
« Reply #1 on: June 29, 2017, 19:28:16 »
Hi, make sure your in line petrol filter is of the larger size. Not enough flow in the smaller one when you go fast. Had the opposite problem a few months back, rubbish at low revs, ok after 2000 but that was just timing and points gap. Found the points very hard to get right with feeler gauges, could only get them set properly with a dwell meter.
        Dave
mdonegan
Carb or ignition?
« Reply #2 on: June 29, 2017, 19:41:36 »
Hi Dave, thanks for the tip. Mike
ted
Carb or ignition?
« Reply #3 on: October 23, 2017, 17:46:03 »
I would be interested to know if this problem was solved and what was causing it. I would have guessed the ignition was not advancing as the revs increased.
mdonegan
Carb or ignition?
« Reply #4 on: November 18, 2017, 21:46:08 »
Hi Ted, you are right! I replaced the distributer and coil and it solved the problem.
   Mike
ted
Re: Carb or ignition?
« Reply #5 on: March 09, 2018, 11:40:42 »
Glad you got it sorted!
