Author Topic: New Member Hello - AC Royal 1925  (Read 8421 times)
j9nno
« on: June 11, 2017, 12:48:07 »
Just a quick post to say hello.
   My son and I have acquired a 1925 AC Royal which is in need of some TLC.
   It is a 4 owner car originally sold in Chester and has remained around the Wirral and North Wales all of it's life.
   Will post pictures soon
   John and Tom Owen
j9nno
« Reply #1 on: June 11, 2017, 15:59:00 »
Reg No. is TU2852
   Chassis No. 30820
   Engine No. 5725 (Anzani)
   Trying to post photo's ?
j9nno
« Reply #2 on: June 11, 2017, 16:38:36 »
[/URL][/img]
   [/URL][/img]
   [/URL][/img]
« Reply #3 on: June 11, 2017, 19:29:38 »
John & Tom
   Congratulations on your AC project and becoming Members of the ACOC.
   A new Comprehensive AC register of all known AC's world wide will go to print within the next few months, If you haven't already registered your AC Royal with Colin Dunn the official "Vintage AC "registrar, his details are on page 6 of the latest issue of ACtion. you need to contact ASAP.
   All the registers were last printed in one volume back in 2001, Up to date individual registers are available in the members section of the Club Forum.
« Reply #4 on: June 12, 2017, 01:45:39 »
Hi & welcome John.
   I stayed at the George & Dragon in Tarvin and there was a period photo of an AC parked nearby which could be yours!
   I'm sure I took a pic of it, will see if I can dig it out for you!
   Best of luck with your project, I'm on Anglesey, So hopefully see you around!
   Nik.
Jam2
« Reply #5 on: June 12, 2017, 06:17:04 »
John, how wonderful to see the car in 'before' condition.
   What is the story behind its state of preservation, when was it last running?
  • Administrator
« Reply #6 on: June 12, 2017, 09:40:06 »
Welcome to the ACOC and very nice to see a survivor not known to the club - this car isn't on the Vintage register.
j9nno
« Reply #7 on: June 12, 2017, 11:30:15 »
   The last owner was John Davies who owned the FORD dealership in Holywell ?
   Don't know when last run and engine has gone off to local specialist for strip and overhaul. So far so good in that the engine was turning freely and the bores are not lipped. So general overhaul and freshen up should see it sorted though I am looking for a starter motor and don't know what I'm looking for so anyone out there who knows please put me on the right path !
   Also the the original carburetor is missing which I guess should be a Claudel Hobson ? Again anyone who knows or can supply let me know.
   The car is generally quite sound in that it has been dry stored. All of the main cabin interior has rotted out but the ash frame is generally pretty good all things considered. We have replaced a couple of the cross bracings and the rear wooden fire wall (behind the front seat) with white oak and 6mm ply. This has all been glued and screwed into place prior to lifting body off chassis. Some repair and replacement needed to timber that is chassis mounted under the Dickie seat but overall no major, major rot found.
   Already sourced replacement speedo and 8 day clock and just cracking on with the chassis and mechanicals for now. Ammeter (CAV) sent off for overhaul/rebuild but again anyone with a spare/replacement message me. Original colour appears to be Green even though logbook says blue ?
   This isn't going to be a concours rebuild. Just planning on an overhaul, tidy up, back on the road and enjoy !
j9nno
« Reply #8 on: June 12, 2017, 21:13:26 »
   Car Number is 30820
jonto
« Reply #9 on: June 13, 2017, 13:03:07 »
I remember the car when it was at the Holywell garage, they also had a small ohc vintage Wolseley, that was in running condition.
j9nno
« Reply #10 on: June 13, 2017, 15:14:09 »
That'll be this one -
   [/URL][/img]
AC-Crankcase
« Reply #11 on: June 13, 2017, 17:04:25 »
It is good to see so many Royals being found and restored, welcome to the club!  My own 1926 Royal 'Uncle Alfred' is now in one piece, with mechanical restoration complete, and I have managed to drive him around the village.  The next thing to be done is the restoration of the wings and bonnet.
   It is here I could do with some help, could some one with an original bonnet top take some photos of it, particularly close ups of the fittings as the bonnet on my car is not original and has no fittings attached??  The sides are the original louvered ones but I want to have a new top made.
« Reply #12 on: June 14, 2017, 01:20:18 »
Ok, so I finally found the photo of a framed photo on a hotel wall in Tarvin:
   ...But unfortunately, unless the registration number has changed, it's not yours! Enhancing the numberplate looks like XW 8513 to me:
Jam2
« Reply #13 on: June 14, 2017, 06:26:04 »
Some 35 years ago when I had to source a starter motor for an Anzani engine, I found that one usually fitted to a Land Rover did the job. Apologies but I can't recall which model.
   http://www.comlec.co.uk/pdf/STOCK-MST.pdf
   Some years ago, I found Comlec Units very helpful in sourcing a replacement starter in another vintage car. Make sure you give them as much info as possible!
j9nno
« Reply #14 on: June 14, 2017, 10:11:06 »
   Must be a different car then.
   Thanks for the info on starters.
   Crankcase - I'll get some photo's of bonnet and post on here.
