Author Topic: MKIV Differential  (Read 3748 times)
jmohara
  • Owner of AK1099
MKIV Differential
« on: December 16, 2016, 23:47:23 »
I have a 1985 AC MKIV with a seized rear differential. Before i start the rebuild process, can someone confirm that the unit in this is a Salisbury 4HU Power-Lok unit?
   Thanks!
   Michael
DWR46
MKIV Differential
« Reply #1 on: December 17, 2016, 01:21:35 »
Yes, it is a Salisbury. It is the same unit used by Jaguar. Years ago, I bought a rebuilt Jag unit with 3.55 gears and it bolted right in without problems.
BBK
MKIV Differential
« Reply #2 on: December 17, 2016, 02:00:39 »
Mine got rebuilt in the last year and believe it is an XJS unit.
jmohara
  • Owner of AK1099
MKIV Differential
« Reply #3 on: December 17, 2016, 02:46:05 »
I know its the same unit as a Jaguar - but I need the actual type number to get all the clearances etc. Anyone confirm its a Salisbury 4HU Power-Lok?
jmohara
  • Owner of AK1099
MKIV Differential
« Reply #4 on: January 02, 2017, 12:56:30 »
I have this in for a rebuild and am still hoping someone can confirm that its a Salisbury 4HU Power-Lok unit. I have the specs for that, and gave them to the builder - so I hope its the right one :-)
wenzeh
MKIV Differential
« Reply #5 on: January 02, 2017, 14:39:31 »
Michael,
   the only thing I can confirm is that the differential is a limited slip differential from Salisbury, of course then with different gear ratios as it was specified.  Further Specifications I do not have.  I was looking in an old Autokraft sales flyer and it did say Salisbury limited slip differential.
   This I found on a Jaguar and a Cobra Forum, independently:
   From 1976-1985, the differential was a Salisbury 4HU Power-Lok that came with either 3.07:1, 3.31:1 (1976-1982), or 2.88:1 (1982-1985) ratios.
   Maybe this can provide the answer you are looking for?
   Heinz
jmohara
  • Owner of AK1099
MKIV Differential
« Reply #6 on: January 02, 2017, 15:14:46 »
Thanks Heinz. I am going with it :-)
