Author Topic: CSX3282 Owners log from 1966  (Read 4744 times)
AC Ventura
« on: September 12, 2016, 14:26:06 »
Hi guys, I normally frequent the MK IV forum as I'm converting a Mk IV to all aluminium FE power.
   Along the way I came across this diary of a buyer who (it seems) bought new 427 Cobra back in '66. It's a bit haphazard in layout, but scroll down an it's an interesting read, especially the problems and the mention of an air valve for the drivers feet, which I would be grateful if somebody could explain?
   http://www.prc68.com/I/CSX3282.shtml
shep
« Reply #1 on: September 13, 2016, 15:53:09 »
I believe the air valve was one of a pair of pull levers on the dash, like a choke knob, which opened ventilation to the driver's and/or passenger's feet.
A-Snake
« Reply #2 on: September 13, 2016, 21:10:36 »
   Pulling out the knob closes the vent, pushed in the vent is open. [:D]
TLegate
« Reply #3 on: September 13, 2016, 23:24:36 »
I know that feeling....
AC Ventura
« Reply #4 on: September 14, 2016, 14:29:17 »
Thanks guys, but if one end of the vent was in the footwell, where was the entry point? Maybe on one the two brake grills on the front end?
   Anyhow, can't be much good in traffic, which is where you really need it unless it was an electric fan.
« Reply #5 on: September 14, 2016, 16:31:30 »
Yep, about as much use as the ashtray at speed!
« Reply #6 on: September 14, 2016, 18:29:23 »
with the heat generated by the 427, it never did much good at all in CSX 3327. Best solution was cloudy days and top not erected!
« Reply #7 on: September 15, 2016, 13:06:33 »
   Said the guy with a reverse of "AC" from the brake pedal melted into his sneaker!
« Reply #8 on: September 15, 2016, 18:57:24 »
Yes, I had forgotten that item..discovered at Watkins Glen after Run to there in rain all buttoned up!
