Hi - I have a 1960 AC Ace with the Weller engine and have some badly worn parts on the clutch actuation that has led to the push rod that fits into the clutch cylinder shearing and hence car unfortunately off the road at present. The parts that I need to replace are the clutch actuation lever that is mounted on the side of the bell housing together with the ball type cylinder push rod end fitting that fits into this lever. Can anyone advise where I can get these parts ?
Thanks for your help,
John Bonafoux
