Author Topic: MK IV engine vacuum  (Read 3080 times)
AC Ventura
MK IV engine vacuum
« on: January 31, 2016, 20:06:24 »
I wonder if anybody knows how many inches if vacuum the 302 5.0 EFI produces at idle? Im considering an engine change and would like to know what is required for the brake servo.
Paul Mundy
MK IV engine vacuum
« Reply #1 on: February 01, 2016, 14:44:40 »
Hi , My Haynes manual for the Ford Mustang 302 efi states 17-22 inches Hg at idle. My Superblower certainly idles in this range.
   Paul
AC Ventura
MK IV engine vacuum
« Reply #2 on: February 02, 2016, 10:14:48 »
Thanks for that helpful reply Paul. You say your s/b idles in this range. Can I presume you've actually tested that?
Paul Mundy
MK IV engine vacuum
« Reply #3 on: February 02, 2016, 11:42:16 »
Yes I have indeed.
   Paul M
silty
MK IV engine vacuum
« Reply #4 on: February 08, 2016, 19:49:04 »
I don't know if it helps but my Lightweight has 14" of vacuum at a 1000rpm idle.  It had a cam change and head work by Uniclip back in the day.  I do notice that heavy braking at low speed drags the revs down below normal idle speed and it actually stalled once.  Considering I don't brake heavily from low speed very often my view is that this minor inconvenience is worth it for the performance gains.
