Hello All,
I made an (extensive) partial list of the items I need. If you can help me locate them or tell me where to purchase them I would greatly appreciate it. Please use the each item reference number below as a guide. If there are other cars that use some of these parts that would help me as well as others in the future, please list them. Thanks, Jeff
Let's begin [
1. Front and back emblems with Bristol banner
2. Front headlight trim rings
3. Chrome hood key hole covers and key
4. Trunk handle
5. License plate light and lens
6. Rear tail lights
7. Inside trunk clips for jack, etc
8. Trunk prop rod or telescoping rod
9. Chrome Gas cap
10. Inside door handles and strikers
11. Side window wing chrome inserts I think there are 8?
12. Do you sell a screw and bolt kit for the car? Just misc. BSF and BSW as well as the flat head machine ones?
13. Complete wiring harness from front to rear
14. Horn and turn signal components and horn cap
15. All of the dash switches and lights
16. Brake master cylinder
17. All of the brake lines and hoses and clips, I do have the 2 junction blocks
18. Clutch slave and hydraulic master cylinder including the lines
19. Do you sell all of the u joints? I want to replace them
20. Front rotors, pads and calipers. Do you sell caliper rebuild kits?
21. Rear shoes, spring kits, and wheel cylinders
22. Emergency brake cables
23. Suspension bushings (16)
24. King pin kits
25. Steering wheel (wood)
26. Interior kit, Black leather
27. Tonneau cover snaps
28. Read end gaskets, side and 3rd member one
29. Steering box rebuild kit
30. Shocks
31. Possible spring bushings front and rear springs
32. Steering shaft gasket that goes on the footbox
33. Rod ends for front suspension
34. Door, hood and trunk weather stripping
35. 4 - AC knock off spinners
36. Over riders
37. Front Turn signal lens's and bases
38. Front Grill and surround
40. Fuel Filler hose to gas tank
41. Smiths heater box and two defrost vent hoses
42. Did some cars come with windshield squirters?
43. Speedometer with clock Ace or 2 litre Saloon
44. All of the other instruments except the rev counter
Whew.... That is a list... [
