Author Topic: Ball joint supplier  (Read 3540 times)
TTM
Ball joint supplier
« on: August 05, 2015, 10:25:33 »
Good morning chaps,
   Could a member in the know point me to a source for front ball joint replacements?
   Thanks in advance.
Ball joint supplier
« Reply #1 on: August 06, 2015, 08:33:22 »
These are available from Brian Eacott tel. 020 8397 8472, or Barry Howsley  tel. 01727 872819.
TTM
Ball joint supplier
« Reply #2 on: August 30, 2015, 18:36:41 »
Thank you for the recommendation.
   On a side note, how much regreasing ball joints of front spindles should help with a light front wheel wobble, if at all? The car feels like a front tyre has gone out of balance (it wobbles a bit at around 65 mph) but last time they were checked, the wheels were all correctly balanced.
Ball joint supplier
« Reply #3 on: September 01, 2015, 20:37:49 »
Greasing the front spindles or ball joints won't really help if there is wear/play in either.
   As for the wheel wobble I would check for play in the front wheel bearings, king pins and steering system.
   Regards Luke.
TTM
Ball joint supplier
« Reply #4 on: June 22, 2016, 12:14:36 »
It turned out it was just a loose wheel bearing. I still disassembled the king pins to give them a thorough clean and regrease and was not able to notice any play in them. Well pleased.
