Author Topic: 1988 Autocraft Mark IV Brake Master Cylinder  (Read 4443 times)
kiwicobra
« on: May 30, 2015, 21:01:40 »
   Any one able to recognize this master cylinder? The rubber bushings between the reservoir and the casting have failed and I need to purchase replacements but no one here in California can identify the master cylinder. The web mentions a Ford Granada and a TR6 as cars using the same but images appear different.
   Many thanks.
ak1234
« Reply #1 on: June 01, 2015, 02:12:00 »
...here is what I have for the replacement booster I purchased a couple years ago
   Ford Sierra Mk1 / Mk2 Brake Booster Servo (Girling)
ANF289
« Reply #2 on: June 01, 2015, 19:30:34 »
This is what I have gleaned from past posts:
   Brake master cylinder is 1972-76 MKI Ford Granada ( 2 versions-7/8"or 13/16" bore).
   Girling part # G 64679152Q123 X
   Original Girling part # 64066627, new reference # PMH117
   Let us know if you confirm any of it.
   Art
« Reply #3 on: June 01, 2015, 20:04:22 »
I sourced one on eBay about 5 years ago, available from UK sources as well.
« Reply #4 on: June 01, 2015, 20:05:56 »
You may want to source as a unit,as I did, ie booster and master cylinder. Diaphanous will eventually fail.
« Reply #5 on: June 01, 2015, 22:26:27 »
These guys have been very good with quality parts in the past:
   http://www.powertrackbrakes.co.uk/
kiwicobra
« Reply #6 on: June 03, 2015, 15:41:14 »
Many thanks - great forum.
« Reply #7 on: June 08, 2015, 13:35:35 »
give these guys a call or drop them a mail with pics, they are specialists for old european ford production cars.
   http://www.motomobil.com/ford-special,210.html
   Uwe
