I have recently replaced my original radiator with an alloy example, and made a serious error in not replacing the fan at the same time. As a result I am now wanting to replace the original 1984 Autocraft fitted item with a modern hi power 'sucker'. Mounting to new fan on the rear of the radiator is relatively simple, but I am v. concerned about getting the old one out.
So, relating to that forthcoming job, my question is;-
What is involved in removing the std front mounted fan, Bearing in mind that it is mounted well up into the front shroud, and has that air deflector plate also fitted into the front of the shroud, preventing easy access to the fan.
Hope someone can tell me its easy!!
