I have an original windscreen frame including the 2 side supports, from a 1962 Ruddspeed Ace. This will also fit early Cobras.
There is no glass. The bottom bar was rechromed about 10 years ago and its been hanging in my garage since. It was not used as I managed to buy the last spare original available from Brasscraft. This will not fit AC or Bristol engine cars as the Ruddspeed was slightly wider. The frame measures 14 3/4" (375mm) deep at centre and is 52" (1320mm) wide at base measured straight not around the curve.Email me at rod@allsworth.net for pictures.
Rod
