Author Topic: Rear Shocks  (Read 3396 times)
David S
Rear Shocks
« on: August 18, 2014, 17:35:15 »
Need to replace the rear shock absorbers on '97 Ace - has anyone got the specifications, etc. Need info to be able to order the correct ones for Spax.
   thanks
DGoose
Rear Shocks
« Reply #1 on: August 19, 2014, 12:28:07 »
Hi David,
   Welcome to the club.
   I'm not sure if the later cars use the same suspension setup as earlier 1994-1996 cars as the underpinnings are quite different I believe.
   Does your car use 4 x rear dampers?
   David G
David S
Rear Shocks
« Reply #2 on: August 19, 2014, 14:28:41 »
Following some discussion Steve Gray, we agreed that it would be best to replace all 4.
