Greg
Unfortunately I do not have any Dyno test results for my Fast Road camshaft for the standard AC Rockers, I am however willing to give you contact details of the guy who has raced with the cam if you send me an Email, he was clearly very happy with the performance.
One interesting thing we found however on testing my new high valve lift Fast Road package was the dramatic affect the SU carburettor condition had on the results, which was caused by too fast a fall of the piston in the dashpot, this was well outside the SU specification & by fitting good dashpots & pistons there was a dramatic improvement in results right through to 6,000 RPM, at this point the torque started to fall but BHP was continuing.
In addition clearly ignition timing, plugs & ensuring the cam timing is accurately set is very important.
So have a good check on some of these areas with your current camshaft before making major investments.
