Author Topic: State side help requested!  (Read 6267 times)
Superarnie Mk2
« Reply #15 on: March 13, 2014, 00:24:02 »
Hi Paul, I'm getting a bit confused now!!
   If the eBay charger is a clockwise pullied blower and the impellor spins in the same direction as the pulley (when all viewed from pulley side), as you have pointed out, how does your own charger work with the scroll side of yours being opposite to this one?
   I think the problem with the eBay item is if the 'main body' was to be mounted and orientated as yours is, the outlet port to the throttle body would be approx 180 degrees out.
   The exit port (on the scroll side) looks to be inline with the pulley wheel, on the eBay item.
   So if you were to look from the front of your car towards the pulley side of the blower, the exit port hose (to the throttle body) would be around about the 10 o'clock position on your car?? On the eBay item it would be approx 2 or 3 o'clock?
   I'm not sure if the scroll housing could be rotated. Could you advise?
   Does that make sense?
Paul Mundy
« Reply #16 on: March 13, 2014, 06:30:34 »
   The scroll housing does indeed rotate.
   By all means give me a call if you want to discuss further.
   Paul
