Author Topic: MKIV (with some AKL features) for sale  (Read 7835 times)
French Frie
« on: February 03, 2014, 08:29:11 »
« Reply #1 on: February 03, 2014, 10:12:10 »
but nice [:)]
302EFI
« Reply #2 on: February 03, 2014, 10:23:57 »
Yes, the car looks very well kept. However, I could not detect AKL features beyond the straight dash and the missing leather cabin edging.
French Frie
« Reply #3 on: February 03, 2014, 10:29:01 »
...and the roll bar !
   edited : and the hood scoop...
302EFI
« Reply #4 on: February 03, 2014, 10:56:14 »
Wasn't a roll bar among the specifications of the standard MkIVs?
French Frie
« Reply #5 on: February 03, 2014, 10:59:05 »
nope ...
« Reply #6 on: February 03, 2014, 11:24:02 »
... and the short nose (but that was standard MK IV on request)
302EFI
« Reply #7 on: February 03, 2014, 13:06:57 »
For standard MkIV specifications pls see here:
   http://www.acownersclub.co.uk/forum/topic.asp?TOPIC_ID=1639
French Frie
« Reply #8 on: February 03, 2014, 16:39:28 »
ok... it wasn't in the specifications, but available as options [;)] ! to me, a "standard" MKIV (as far as it has ever existed !) is a kind of 427 street version (or AC289 without wire wheels), ie underbody exhausts, no hood scoop, no roll bar, chrome bumpers,  etc...
« Reply #9 on: February 04, 2014, 10:05:40 »
Don't agree to you FF.
   The upper left corner of the company brochure shoes a driver side roll bar as standard for later cars doesn't it?
   Therfore it was not on the option list.
   Will check my early brochures but i think it changed from 86 on.
302EFI
« Reply #10 on: February 04, 2014, 10:08:58 »
And the photo in the company brochure shows a MkIV with a hood scoop... ;-)
« Reply #11 on: February 04, 2014, 10:16:36 »
Photos are teasers and mostly not related to base versions :-) the same with actual brochures for all OEMs, the text is relevant.
« Reply #12 on: February 04, 2014, 17:36:38 »
Seems that manufacturers often show options in photos. French Frie, check the factory build sheet that came with red head, perhaps that will settle it. I believe you are correct though, 289 sports with a 302/5sd, under car exhausts, no roll bar, no knock spinners( nuts were std) no hood scoop. But you could have many factory changes done.
302EFI
« Reply #13 on: February 05, 2014, 10:40:55 »
The only point I intended to make is that roll bar and hood scoop do not belong to the items which distinguish a Lightweight from a standard MkIV.
« Reply #14 on: February 05, 2014, 20:37:30 »
Correct
