Author Topic: Expansion tank  (Read 6332 times)
French Frie
Expansion tank
« Reply #15 on: January 28, 2014, 21:45:12 »
Here are the pics from Nick :
   Overview :
   The header tank :
   Its bottom detail :
   Thanks for sharing, Nick !
Hobo
Expansion tank
« Reply #16 on: February 02, 2014, 07:46:02 »
As Uwe (Westcott) mentioned I bought a Fluidyne radiator for my “Sleeping Beauty” and I did the measurement.
   The dimensions are: 610 mm wide, height 460 mm, 90 mm thick.
   All 4 corners are chamfered approx. 25 mm / 45°.
   As this radiator is layed back for cars with MkIII-frame, the coolant entrance is angled approx. 20° upwarts.
   I looked at my MKIV and assume this radiator will fit in. The Fluidyne radiator is approx. 10mm wider than the original radiator (which is approx. 600mm x 480 mm), there will be some space left between the small front tubes, however it will be tight .  The coolant entrance will come closer to the body/hood – but also feasible.
   The “Serck” plate has been offered once by Acton Customs Enterprises or is still available in combination with a top cover to create a more periodic correct look (no need for MKIVs): http://actoncobra.com/index.php?main_page=product_info&cPath=41&products_id=118 .
French Frie
Expansion tank
« Reply #17 on: February 03, 2014, 08:49:44 »
thanks for the info, Hobo... Even if it's not directly topic related, each and every info is useful !
   here's a post from Emmanueld on the 428 forum about the Fuidyne radiator : http://www.acownersclub.co.uk/forum/topic.asp?TOPIC_ID=1911
