Author Topic: Stub axle carrying nut needed urgently  (Read 3093 times)
« on: January 06, 2014, 16:53:17 »
Hi guys, does anybody know where I could locate a stub axle carrying nut for the Frua rear differential?  It's pretty worn out.
   Stub axle retaining nuts Salisbury.
   Id 33.36 mm.  1.31 std
   Thick 7.12 mm.   .280 std
   Nut 1.861 std 47.27mm
   Here are 2 pictures, one of the axle and nut and one of the nut alone.
   [/URL]
   [/URL]
   Thank you,
   Emmanuel [:)]
« Reply #1 on: January 06, 2014, 23:31:32 »
Emmanuel, that is an interesting photo' as it shews the later single piece Inner Drive Shaft. I wonder if that is original or has it been uprated at some time ? In any event you will likely get your replacement nut here:
   Pete Yale, Sales Co-ordinator
   Tel : + 44 (0)1212492549
   Fax : + 44 (0)1212492119
   Mob : +44 (0)7753845661
   e-mail: pete.yale@dana.com
   Dana Light Axle Products Group
   Birch Road, Witton, Birmingham, B6 7JR, United Kingdom
   Failing that BPA Engineering are very good, see my previous post at http://www.acownersclub.co.uk/forum/topic.asp?TOPIC_ID=2756
   Either way you are in the fortunate position of having a set up that can make use of the later, stronger, components and it may be that you can find the nut easily, nearer home, via a Jaguar spares supplier.
« Reply #2 on: January 07, 2014, 02:32:38 »
Thank you for the contact, I have made a call to a Jag recycler and I am told the early  XJs'  May have the same nut. The man is checking for me. I think the single piece axle is stock on the  Frua because my friend Jeffrey's earlier car is also set up the same way.  It looks like the Mark IV uses a similar set up. See the Mark IV forum
   http://www.acownersclub.co.uk/forum/topic.asp?TOPIC_ID=224
   On page 5
   The Frua is heavier than a Cobra and AC probably felt the spline stub axles were not strong enough for this car.
   Thank you,
   Emmanuel[:)]
