Dear all,
Has anyone experienced brake bleeding problems with these cars. I am at the stage of bleeding the brakes on my Superblower build project. I have noticed that the remote reservoir is only a little higher than the location of the master cylinder. The low pressure brake hoses fitted to the outlet ports on the reservoir have to swoop down before they can bend round and head off to the master cylinder, this causes a bit of a trench and an 'uphill' section of piping and the gravity feed to the cylinder is then lost. As a result, I am struggling to do the first bleed of my brake system. Has anyone experienced this problem and if so, how did you overcome it?
I have pumped the pedal a million times but don't have any fluid coming out of the exits of the cylinder. I may have to pressurise the system with a shreader valve type pump device in order to do the first bleed of the system, the fluid then may work in a syphoning type effect???
Any advice would be welcome.
Many thanks
