Hi gang -
I have been off the forum for a while and sadly off the track due to work needs. Must pay the bills!
Anyway, I raced my ACECA for the first time in a year. It was great to be back on the track again. Oh how I have missed her.
Now for the update...
The good news - the Winchester stub axles along with the fix for keeping the bolt from unscrewing worked a charm.
The bad news - Part 1
Firstly, during my first practice session, in a long left hand carousel, I heard a bit of a "bang" followed by a pronounced rubbing sound of my backing plate on my left rear drum. Not good. I pulled into the hot pit and got out and gave the left rear a tug. WOW! significant movement. So, I limped back to my garage and put her up on jacks. We pulled the spinner off and THE TOP 3/4 INCHES OF THE BOLT HOLDING THE STUB AXLE TO THE HUB FELL ONTO THE GROUND!!! Yes, that's right, a 5/8" x 1 1/2" grade 5 hardened bolt SNAPPED in the hub.
After 3 hours of hitting every hardware and automotive store in a 40 mile radius, I finally found a Grade 8 replacement for the sheared bolt. We replaced both rear bolts to be safe. Problem solved! Or so I thought. Well, at least that problem was solved. However, my mechanic and I were (and still are) completely baffled by the bolt shearing. We cannot understand how it could have happened. Perhaps the next bit may help...
The Bad News Part II -
After running in my afternoon practice session, I noticed I was having backing plate rubbing sounds again. I finished the session and put the car back on jacks again. This time BOTH rear wheels were now loose! However, the bolts had not moved at all due to their retaining plates. Yet, after removing the retaining plates each bolt could be turned at least 1/2 turn before snugging up again. No, the bolts had not stretched. The only thing we could conclude was that the wheel bearings were compressing in some way...not good either. But, at least we were able to snug them up again and get ready for the race the next day...off to the pub.
The bad news part III -
The next morning I went out for a 15 minute warm up session in advance of the afternoon race. 5 minutes in, the rubbing started again in earnest. I finished the session and went in. Yup, up on the stands she went. This time the bolts were tight! But the wheels were still very wobbly. Game over. I had no interest in losing a wheel in the race. We were done...
The only thing we could surmise without a complete tear down was that the bearings were shot. BTW, these bearings only had one session on them and were the same type I had used for the previous 3 years.
One MAJOR difference was that for this weekend, I was using AVON's instead of Dunlops. I knocked 5 seconds off of my best laps ever with these tyres. Their grip was vastly superior. So, the thought was that this increased grip/load was just too much for the bearings to handle. However, I had run them once before with the stock stub axles without issue. So we are concerned that the design of the Winchester stubs may not be supporting the bearings correctly.
Now it's over to you...!
- What do you think happened? Why did the bolt shear?
- What are my options for different bearing choices?
- Upright choices?
I look forward to a healthy discussion!
Cheers,
Rob
