Looks like a busy month of May coming up.
Hi-tech have been very helpful with providing drawings and have offered to assist with a couple of issues
1. There is one weld on the lower steering column tube to the splined section that goes to the rack - will remove and have a one piece shaft machined, got a quote from reputable machine shop for NZD$200 (GBP100) and two days to carry out the work
2. The safety loop for the prop-shaft is 13mm solid bar and should be 22x3mm tube - technical committee rejected this and will have a new 22mm solid bar loop fabricated, just waiting for the committee to give me the minimum material spec. Drawings supplied by Hi-tech
3. The brake pedal lever is 6mm, not 8mm and is welded onto the lower bush - technical committee rejected this and a new one will have to be made. Hi-tech have offered to provide this
4. The door latches are the standard Wilmot Breeden type latches, have to prove that they are burst proof - technical committee have rejected these and will probably remove them and bolt the doors closed for the certification. Other option is to modify and install approved burst-proof latches, a route I do not wish to go down (starting to make irreversible mods)
5. The hi-level brake light is too small - new one has arrived and will be installed temporarily until such time as a permanent bracket can be machined to mount it off the existing seat belt loop mountings
6. The rear reflectors are too small - new ones have arrived and will mount these off the rear nudge bar mounting
7. Several bolts do not have two threads protruding from the nut - will be replaced
8. Discovered last time home that the toe can not be adjusted in past 1/8" toe out. The extension piece on the end of the tie rod has a lock nut on it which prevents the extension piece going into the ball joint any further. This will have to be removed and go onto the inboard end, same as per the original cars.
9. Camber/castor/tracking need to be set up
10. Discovered alternator was not charging, will have to be removed and repaired/replaced
Have got 21 days at home, 7 of those will be on an annual fishing trip
leaving 8 days to get as much done as possible before the next inspection on the 15th May
