Update... As the Ford bushings didn't fit, I decided to make it on my own. Here's the column:
You can see the triangular shaft, and the splined end which was obviously welded by AC ... The diameter is not 3/4" (like MGB), but only 14mm (9/16")!
Here is the plate that supports the bushing :
So, I took a piece of nylon, and made a bushing ..' But unfortunately, I don't have a lathe, so have to be creative [
] ! The requested diameter is 22mm (OD) and 14mm (ID)
The inner hole is enlarged :
And bushing is fitted to the plate :
To be continued ...
