Author Topic: AC MK IV Main Tube Bracing?  (Read 2182 times)
« on: March 28, 2013, 14:11:15 »
On some inside pictures from the Autokraft plant you can see the MK IV main frame still in the jig without paint.
   A closer look shows grinding points on top of the main frames in equal distances.
   It looks like something inside like a brace made from flat material was welded through the tubes and grinded afterwards.
   Is it really a brace going through the whole length of the main tubes?
   Is it flat material or anything else?
   My car is actually sitting on a small scissors lift to replace all suspension rubber caps and the doors open and close without any problem.
   The bracing would be a explanation for that kind of frame stiffness.
   Uwe
« Reply #1 on: May 04, 2013, 14:12:41 »
No insider infos or pictures, nothing??
   Come on.
