Author Topic: Bristol crank wanted  (Read 2199 times)
Glen Smytheman
« on: March 06, 2013, 07:45:43 »
Hi all,
   A friend over in NZ with a Bristol 405 has a requirement for a good used/new large-nosed crank.  I undertstand Farndon sells new cranks at about GDB 1750 + VAT but does anyone else have a good used one/new one for sale.  Will consider from anywhere in the world.  Many thanks, glen smytheman
« Reply #1 on: March 06, 2013, 08:37:08 »
You should post this message on the Bristol Cars Forum as well. Good luck.
3.8Jaguar
« Reply #2 on: March 08, 2013, 11:18:59 »
The only crank that I am prepared to let go is a Big nose which has been soft metal sprayed in some of the journals hence the price tag £300.However it would be fitted at the new owners risk. Rough measurements are 2.118 and 1.749 very approximate, it would require a grind.
   Other than that I would suggest getting one ordered from Farndon sooner rather than later, they are a good Firm and produce a good product but their lead times can stretch out.
   www.bristolengineering.co.uk
