Author Topic: MK 1V petrol tank  (Read 2377 times)
nick Godridge
MK 1V petrol tank
« on: November 21, 2012, 13:30:08 »
Hi all,
   Can anybody tell me what is inside the fuel tank of my MK1V?
   I have been syphoning out sme contaminated fuel and now can not remove the syphon tube.
   The last few cms of the  flexible tube have a rigid non return valve, and this seems to be stuck under something.
   Any help seriously appreciated.
MK 1V petrol tank
« Reply #1 on: November 23, 2012, 11:59:52 »
Maybe it stucks underneath the fuel sender or the divider walls /anti motion baffles / slosh baffles. Twist or rotate the tube during the removal, it will come out (sooner or later).
ak1234
MK 1V petrol tank
« Reply #2 on: November 23, 2012, 23:13:36 »
... If memory serves me correctly when I was searching for my fuel pump ... the tank has a baffle or two and as westcott mentioned you might be hooked on the sendor.  If you take the cover behind the seat out there is access to the sendor ... once removed you can see in the tank.
   Ron
