Author Topic: MkIV Front Inner wings.  (Read 2205 times)
Alan Faulkner-Stevens
« on: October 26, 2012, 08:11:46 »
In amongst my concours Shelby restoration work i have restored two MkIV Lightweights. This has allowed me to manufacture my own moulds to produce the front fibreglass inner wings for both LHD and RHD versions, should anybody need some. I can also add greater clearance around the steering column shaft on the LHD cars if required. This i found much needed on a cars conversion to an early style steering column i completed.
French Frie
« Reply #1 on: October 26, 2012, 08:44:28 »
Hi Alan,
   no need for the inner wings, but the info is stored, thanks... But could you be more precise regarding the steering column, as I actually think it is too low, especially with a 15" wheel.
    I plan to change the Ford setting to a VW switch (with a modified column), but I assume it won't change the mounting points of the column, so I'm interested in your offer... and for my culture, why are LHD settings different from RHD ones ?
« Reply #2 on: October 26, 2012, 21:20:00 »
In my experience i have found a slight fit problem with the drivers side LHD inner front wing, which i believe may be from build differences. This manifests itself with the outer/upper edge of fibreglass inner wing flange not following the shape of the inside of the aluminium outer wing correctly. Even with the sealing rubber attached to the fibreglass edge, it did not seal against the aluminium cleanly. To improve this, i felt the inner-wing panel needed to fit further into the car, thus improving the relationship of the two surfaces to each other, but by doing this it closed the gap between the intermediate steering shaft and the panel. Hence, improving the fibreglass relief around the column. As to the early conversion, i have always been reasonably happy with the column height, basically because of its exit position from the dash panel not really giving a great scope for change. However of removal of the Ford switchgear column for replacement with the early style simple column, as supplied, i found the column outer tube end struck the accelerator pedal, the simple upper fixing was not good enough to support the column tube safely, so an extensive lower bracket needed designing and fitting. Finally, because of the cars original set-up the inner spline shaft didn't work in the new configuration, requiring the design and manufacture of a completely new inner shaft.
   As to why a standard early RHD specified column assembly wouldn't properly fit the LHD i cannot truely say. I suspect variances between the cars, manufacturing changes as the model progressed, and a number of small detail changes that you are always likely to find on a small volume hand built car.
