Author Topic: original catalytic converters  (Read 2628 times)
SwissAKL
« on: September 20, 2012, 09:59:40 »
Hello Everyone,
   I have a question regarding original catalytic converters fitted to EFI MK IVs, do you know what numbers they should bear ? Any official documentation on this ? That would be a great help !
« Reply #1 on: September 20, 2012, 13:44:05 »
They are from a 1985 Mustang with EFI. I will look up the numbers and post them.
SwissAKL
« Reply #2 on: September 24, 2012, 17:34:07 »
That would be awesome if you could post the numbers (there are 4 cats, 2 each side), I'd be grateful for your help. Alex
ANF289
« Reply #3 on: September 28, 2012, 02:43:06 »
Front cat has following embossed info visible through heat shield: 1st line -  FORD 5F25C, 2nd line - E7Zc-DA 5, 3rd line - AZA// 8-041.  Rear cat: 950051-1.  Left side turned 180 compared to right and front turned 180 compared to back.  All 4 look identical.
« Reply #4 on: September 28, 2012, 12:17:14 »
Still working on correct Ford part numbers. I will post when confirmed.
