Author Topic: front stabilisator  (Read 2936 times)
AEX166
front stabilisator
« on: August 13, 2012, 20:50:26 »
hi i am looking for a Front stabilisator for my AC ACE ! where can help?
   regards stefano
tim isles
front stabilisator
« Reply #1 on: August 14, 2012, 08:32:14 »
Stefano,
   I use the anti-sway bar made by Nigel Winchester on my Ace. It works well, tightens up the front and prevents the car from adopting extreme angles of roll. I know others who also use and speak well of this accessory from Winchester Motorsport.
   Tim
front stabilisator
« Reply #2 on: August 14, 2012, 09:41:29 »
Stefano..
   Anti roll Bar.
   As you live in Switzerland a off the shelf alternative to Nigel Winchester's Anti Roll Bar, would be the standard  TR6 Anti roll bar kit,  used by many AC Ace owners with great success.
   This subject was on the Forum a few years back, I believe part numbers  were confirmed at the time.
   If not I can Confirm, just need to go through receipts.
   Either  system will tighten up the front end of your Ace. However if you are planning more track use than road use you might want to experiment with different diameter roll bars, plus set it up for easy adjustment to suit wet or dry track conditions.
   Cheers
   Keith ..[;)]
AEX166
front stabilisator
« Reply #3 on: August 14, 2012, 18:59:39 »
hi thanks for your tipps. i think the  TR 6 variant is the best for my. keith when you have the parts number can you send my this
   best regards stefano
front stabilisator
« Reply #4 on: August 14, 2012, 19:16:48 »
I found the old thread Keith was refering to, HERE.
Originally posted by AC Ace Bristol, June 2008 :
   Hi. I have a TR6 Anti roll bar fitted to the front of my 1957 Ace Bristol, has served very well over the past 7 years.
   Purchased from TR Shop in Chiswick, London.Pparts as follows:
   1  x   215647        Anti roll bar   TR6
   2  x   152143A       Roll Bar link   TR6
   2  x   123502        Clamp Roll Bar  TR6
   2  x   123998Poly    Roll Bar Bush poly
   2  x   139126        U Clamp Roll Bar  TR6
   4  x   517985P       Poly Bush Roll Bar link
   Hopefully the details above are of interest,  Haven't fitted Anti- roll bar to rear, suggest you contact Andy Shepherd who has fitted roll bars front & rear and races Ace Bristol with success... as does Tim pearce, Paul Conway etc etc.
   Andy Shepherd   email:-    shepherd289  at  aol dot com
   Good Luck
front stabilisator
« Reply #5 on: August 15, 2012, 09:48:15 »
Stefano
   And there by Magic  (sounds familiar)
   Is the Info required...........  thank you Nik.
   Keith.[;)]
AEX166
front stabilisator
« Reply #6 on: August 15, 2012, 23:05:59 »
great, thNk you all cheers stefano
