Author Topic: Early Ace fuel line routing  (Read 2250 times)
aex125
« on: February 03, 2007, 01:28:58 »
Does anyone know if there was a standard fuel line routing used on the early Aces? Currently I have the line routed along the main frame tubes but dipping below them when they encounter a cross tube. This means the fuel line dips lower than the frame rails which concerns me a bit as do not like the fuel line in an unprotected place. Also, should the line be rubber or was it a hard line?
