I recently replaced the right rear inner and outer wheel bearings on my Aceca. Within about a month after doing so, it appears the outer bearing has failed miserably as the wheel has a large amount of play in it. So much so that the brake drum rubs on the backing plate unless the car is going perfectly straight. Any small amount of lateral movement of that wheel makes a nasty scraping sound. I suspect the bearing is defective but wanted to get some opinions on whether it was the correct bearing in the first place. The bearing that was removed from the car was an R&M bearing that, I am told, is a "max" style bearing as it has a total of 30 balls. The relatively high number of balls means the collars must be slotted to allow for assembly at time of manufacture. Photo is below.
The replacement bearing is manufactured by SKF and, I am told, it is a "Conrad" style bearing. It has a total of 22 balls and because it has fewer, no loading slots are required. I would also assume that with 8 fewer balls, it is not as robust as what was in there previously. A photo is below.
Can anyone tell me if the "Conrad" style, SKF bearing is what is being used these days? I cannot find a "max" style bearing and am told it is likely no longer being manufactured. If the SKF bearing is the current replacement for our cars then I will assume mine was defective. If not, what is the best replacement?
Thank you in advance for any advice.
Greg
